    Issues with importing DXF. (GKWare Simple DXF)
    3 Posts 3 Posters 3.1k Views 3 Watching
    • M
      mathewbailey08
      I'm having issues with importing a DXF in Sketchup Make 2017 using GKWare Simple DXF.
      When I try to import a DXF, it doesn't show in SU Make 2017.
        Have you tried Zoom Extents after importing?
        How about sharing the DXF file so we can see if there's something about the file that might be the problem.
        • G
          Garry K
          Simple DXF only works with files created by cutmaster or with files created with Simple DXF. It is not intended to be a generic DXF utility. It focuses on maintaining proper arcs, and polylines and allows you to control directionality for CNC equipment where direction is important as with certain machining operations for CNC routers.
