    Simple, Basic Plugins (Mirroring, Fillet, Extend, etc) ?
    4 Posts 4 Posters 2.2k Views 4 Watching
      archlab7
      Can someone direct me to a Plugin (an RBZ, not RB) that has BASIC, useful drawing tools such as Mirroring, Filleting, Extending, Drawing a Line at an Angle...you know? The stuff that actually works like most of us do.
      Perhaps a better way to describe what I'm seeking is that I am, yet another, former AutoCAD User who has been extremely productive in that universe, but struggle with the way SketchUp functions when it comes to laying out drawings. I will evolve, but need some good utilities to help the process.
      And why is it so hard to find this stuff?
      Thank You.
        Thank You.
        Search in the PluginStore for examples - there are many.
        https://sketchucation.com/pluginstore
        It is easy to find RBZs of hundreds of Plugins there...
        Flip [Mirroring] is built into SketchUp [context-menu] - my Mirror tool also works more like AutoCAD's
        Basic Filleting is built into newer SketchUp versions [Arc+click], there are also Filleting Plugins [like my 2d-toolset's].
        If you want 3d-filleting of corners Fredo has suitable 'rounding/chamfering' tools...
        Extending lines is also possible using Move, but again my 2d-tools includes some Trim/Extend/Adjust tools.
        You can set a guide-line at any angle using the Protractor tool, then draw along that.
        Or use the Rotate tool on and existing edge to rotate that.
        If it's a set of survey points and you want to input point/angle[bearing]/length there are plugins to do that - I don't think they are in the PluginStore, but search the Plugins forum for posts discussing this with external links - a very quick search brought up this: http://rhin.crai.archi.fr/rld/plugin_details.php?id=434
        There's also a long thread discussing "plugins for architecture" which you might find helpful and has many links off...
        https://sketchucation.com/forums/viewtopic.php?f=323&t=59471&hilit=survey+tool+survey&start=60
        • pbacotP Offline
          I would suggest TT ThomThom's edge tools, specifically the tool to offset a single edge on a face. More CAD-like. In TIG's extrusion tools I use extrude edges by vector a lot. Not sure if this has an AutoCAD equivalent but it seems like a tool that should be a basic SketchUp function for building up surfaces from existing geometry--in a simple-to-use fashion.
            About .rb / .rbz
            Zip the .rb , rename it in .rbz : you have an .rbz ! πŸ˜‰
            a free zipper if you have not : https://www.7-zip.org
            (maybe prefer zip than 7z for mor compatibility...
