    [REQ] Component axes to World
    6 Posts 4 Posters 1.4k Views 4 Watching
    • pbacotP Offline
      Has anyone solved this in a plugin? I imported various components and I want the axes of all changed to the world axes.
      I don't care about the origin so much in this case, just want the alignment of the axes changed in all the components to be oriented to the world.
      I don't want the components or any of the contents moved or rotated--just the axis orientation.
      I see some threads on this but haven't see a solution (plugin).
      Doing it "manually" now, but it's a little cumbersome.
        Axes Tool by Thomthom ?
        • pbacotP Offline
          I saw that but it doesn't say it does what I want.
          • JQLJ Offline
            JQL
            Here you go:
            https://extensions.sketchup.com/en/content/cg-adjust-n-export
            Try tgis one it does what you want and more and it does it nicely. I use it sometimes when setting up my projects...
            www.casca.pt
            Visit us on facebook!
            • pbacotP Offline
              Thanks! That looks great! Peter
              • O Offline
                optimaforever
                I use TIG's Originate to Component axes since 2012.
                https://sketchucation.com/forums/viewtopic.php?f=323&t=43582&p=620193&hilit=originate+to+component+ax#p620193
                And Chris Fulmer's Center on Origin since 2009:
                http://sketchucation.com/forums/viewtopic.php?p=152438#p152438
