[REQ] Component axes to World
Has anyone solved this in a plugin? I imported various components and I want the axes of all changed to the world axes.
I don't care about the origin so much in this case, just want the alignment of the axes changed in all the components to be oriented to the world.
I don't want the components or any of the contents moved or rotated--just the axis orientation.
I see some threads on this but haven't see a solution (plugin).
Doing it "manually" now, but it's a little cumbersome.
Axes Tool by Thomthom ?
I saw that but it doesn't say it does what I want.
Here you go:
SketchUp Extension Warehouse
Your library of custom third-party extensions created to optimize your SketchUp workflow.
(extensions.sketchup.com)
Try tgis one it does what you want and more and it does it nicely. I use it sometimes when setting up my projects...
Thanks! That looks great! Peter
I use TIG's Originate to Component axes since 2012.
https://sketchucation.com/forums/viewtopic.php?f=323&t=43582&p=620193&hilit=originate+to+component+ax#p620193And Chris Fulmer's Center on Origin since 2009:
http://sketchucation.com/forums/viewtopic.php?p=152438#p152438
