    Change wall thickness of a box
    3 Posts 3 Posters 1.2k Views 3 Watching
      titilecostaud
      Hello, I want 3dprint a small box, but the wall thickness is too low (wall not printed), and i don't find how to change it without all restart.
      Thanks for your help.
      singleboxssk60.skp
      • ecatiE Offline
        ecati
        Did you import this object from another program?
        • BoxB Offline
          First you need to import the (I'm guessing .stl file into sketchup at a larger scale. This will allow it to import without all the missing faces. Once you have done that you can smooth all the triangulated edge so you have a solid that you can then work with.
