Change wall thickness of a box
Hello, I want 3dprint a small box, but the wall thickness is too low (wall not printed), and i don't find how to change it without all restart.
Thanks for your help.
Did you import this object from another program?
First you need to import the (I'm guessing .stl file into sketchup at a larger scale. This will allow it to import without all the missing faces. Once you have done that you can smooth all the triangulated edge so you have a solid that you can then work with.
