    Problem with PDR extension
    extensions
    3 Posts 3 Posters 3.1k Views 3 Watching
    • H
      huckrorick
      I wanted to test out the PBR extension.
      I'm using SketchUp Pro 2016
      I got an error message saying I need Ruby 2.2.0 or SketchUp 2017.
      Can I fix this?
        Can I fix this?
        Of course yes!
        You must run SketchUp Make 2017 (or Pro) minimun!
        You can find it here!
        • BoxB
          Your thread title says PDR your post says PBR! Which is and what is it?
          Knowing what the extension is would help us tell you if there is an older version that would work with your system or if there was another extension that would do what you need.
          But from the information given, Pilou has given you the only answer possible.
