    Global attributes
    10 Posts 3 Posters 9.6k Views 3 Watching
    • O Offline
      Orionis98
      I'm starting to study DCs, with a quite good knowledge in programming with different languages.
      My question, made simple: is there a way to have some global attribute in a scene?
      I made a number of kitchen dynamic components (I'm sure this is common starting point, all with their own attributes for materials.
      It is boring to select each single element just to change colors, so I wonder if I can define somewhere in an upper level the materials to be referenced globally by all the elements.
      This is also to avoid to create a list of materials for each elements.
      I thought to use 'Choose' with an index inherited from a 'global' array, but where and how?
      Hope this is clear, thanks
      • P Offline
        pcmoor
        You could create a group or component called kitchen, then build or place components in this environment. "Kitchen" would hold the global attributes. So newly inserted cabinet DCs will read with attributes =parent!.... and update. You could save this file as a template.
        • O Offline
          Orionis98
          Thanks for the answer; this was my original idea, but I find it an impractical solutions because you have to deal with a new 'macro' component to be exploded for any change to one of its sub components.
          I hoped there was a way to define some out-of-context attributes.
          If there aren't, I will adopt what you suggest.
          • P Offline
            pcmoor
            There are techniques of achieving this
            sample attached where one can choose the default (global) or own input for a bench top
            build 1.skp
            • O Offline
              Orionis98
              Thanks again for your support; unfortunately I have SU 2016 and can not open your file.
              I would ask you another question (I might open a new topic, eventually): following a 'plain' approach, thus assemble a macro component to drive all the real elements, I still have a very boring issue: with tens of material selectors (at least 2 for each element, plus the globals ones) I have to declare a list of materials (the same) for each.
              Is there any way to 'copy & paste' the list from one component to another one?
              Thanks again
              Giacomo
              • P Offline
                pcmoor
                Giacomo,
                I downgraded the file to 2016
                To copy and paste you need to use attribute inspector from the extension warehouse or
                https://sketchucation.com/pluginstore?listtype=1&author=0&category=0&search=attribute+inspector&submit=%3F
                then find the _option in the dynamic attributes,you will see that have URI formatting. Copy & paste the values using control c,v, You need to remove an "&" to add on further copied values
                One can use an excel macro to read and convert a list too
                https://www.youtube.com/watch?v=O4gcm8HXLV0 shows the use of the macro and Attribute Inspector
                you need to private message your email to get the excel macro, as can not load to this forum
                build 1.skp
                • O Offline
                  Orionis98
                  @pcmoor said:
                  Giacomo,
                  I will study and test your material in the next days; I'm sure they will help a lot.
                  Thanks for your excellent support
                  Giacomo
                  • pbacotP Offline
                    I don't know if this works in your setup or dynamic components for that matter. And I suspect it is no good if you are outputing the chosen material (color) in some bill of materials... But I use
                    "Material Replacer" to globally change a material in a model.
                    • P Offline
                      pcmoor
                      @pbacot said:
                      "Material Replacer"
                      I believe this is an excellent idea, it works well with DCs, provide you first initialize the material. Reports okay too. I will adopt this in my workflow. Thanks!
                      • O Offline
                        Orionis98
                        Thanks for the hint; I'm sure it is very usefull, but at the moment I suspect to have a serious performancies issue, for which I will post right now in a new topic.
                        Giacomo
