    Non-solid objects (Plugin: Solid inspector)
    4 Posts 4 Posters 1.7k Views 4 Watching
    • O
      ozgesuvari
      Hi, i'm trying to use slicer 5 plugin which is this one; https://sketchucation.com/plugin/781-tig_slicer
      And for using this plugin i need a solid object. In spite of i'm using "solid inspector" for checking if it is solid or not, it's still not solid.However, solid inspector says everything is ok, objects is still manifold.
      How can i convert it to solid and find out which part of the model i was mistaken.
        Try also Solid Solver by TIG!
        You can also export as OBJ Format Tig has also an Import Export OBJ format if you have not the SU Pro
        Then run the free Mesh Mixer
        Menu Analysis / Inspector / auto repair all 😄
          Is face orientation correct? Do you have exposed back faces?
          • BoxB
            We're all guessing, add the model and we can check it.
