    How to draw a straight line with precise length
    layout
    23 Posts 5 Posters 13.1k Views 5 Watching
    • M
      Mikar
      Hi all,
      what I can do is:
      • hold down the 'shift'-key to draw a straight line locked to x or y axis
      or
      • type a number while pointing the line's end somewhere in oder to draw a specific length.
      But I simply cannot get both features working together at the same time.
      Is there a way?
      Cheers
      Mikar
        Yes. It can be done. Click and release to set the starting end. Drag the line out in the direction you want it to go without holding the mouse button. Let go of the mouse and type the desired length. Hit Enter.
        Click on the picture
        • P
          Philw
          Nice to know,
          But if I have a scrapbook Item and want to move it precisely (let’s say an 1” or 1/8”) can I do that?
          When I type a dimension I get the invalid string message.
            @philw said:
            Nice to know,
            Yes. Definitely.
            What exactly are you typing?
            Click on the picture if it doesn't move.
            • P
              Philw
              I tried both typing: 1/8" and typing :1/8", 1"
                Are you clicking in the Measurements box?
                  That's good that you're just typing. What units have you got selected in Document Setup>Units? What is the Precision set to? What happens if you don't enter units?
                  • P
                    Philw
                    no,
                    I am taking it like in SketchUp, just typing and return.
                    I can see what i am typing show up it the box before i get the message once i hit return.
                    • P
                      Philw
                      units set to fractional
                      Precision 1/8"
                      "What happens if you don't enter units?"
                      Not sure what you mean?
                        Just type 1/8 or 1 or .125 and hit Enter.
                        Set precision higher, like 1/64" and see what happens.
                        • P
                          Philw
                          That works, ☀
                          that has been a thorn in my side for a while. I wonder what else I am doing wrong 😮
                          Thanks for all your help.
                          I need a doh! boook for Layout
                          • P
                            Philw
                            I must be doing something wrong some of the time. I am old school cad. I keep wanting to pick it and start the move, then type the distant. I am just picking the object and typing the new length, this works some time and other times, not.
                            is this written down somewhere where i can read how this works or is it on the layout help sites?
                              @philw said:
                              That works, ☀
                              Good. You should be able to type the units but as long as they are the default, you don't need it anyway.
                              I might be able to give you some idea if I saw your LO file.
                              You're welcome.
                              A new book to publish. 😉
                                Hang on and we'll look at it together. I have to finish an overseas call.
                                • P
                                  Philw
                                  I'll try and send a file from work to
                                  I'll try and send a file from work tomorrow..
                                    Do you want to try looking at LayOut with me using a screen share. I can set that up.
                                    • P
                                      Philw
                                      that would be great
                                      • M
                                        Mikar
                                        Hi Dave,
                                        thanks for your explenations!
                                        Let me just skip back to my initial question. The problem I have is that I cannot type the desired lenght while holding down the shift key to keeop the axis locked. With 'straight line' I ment locked to x or y axis.
                                        Any idea how to do that?
                                        Cheers
                                        Mikar
                                        • pbacotP
                                          If you press shift and snap to x or y directions, move the cursor in the direction you want. then while holding shift you can hit a number key on the numerical key pad and return, that should work.
                                          But it's not generally necessary to press shift. The line tool will show a red or green trace as it locks into the x or y axis. You can then hit any numbered key (or length e.g. 2'7 ) and return.
                                          I think the problem is with heavier lines at closer zooms this indicator is not very visible if at all. That may also be worse on retina displays. The line direction definitely "snaps" though.
                                          • M
                                            Mikar
                                            Well, my numberpad doesn't accept any entries while I hold down the shift key (maybe it works on your Mac, but not on my MS).
                                            However, I noticed that once the desired axis lights up (x in red, y in green) I can release the shift key and the line will stay on the desired axis, then I can enter the length.
                                            Problem solved, thank you all!
                                            Cheers
                                            Mikar
                                            • 2 / 2
