    Revit > sketchup - best workflow?
    4 Posts 4 Posters 2.0k Views 4 Watching
      Jorgensen
      Is there any good tips for "connecting" revit and sketchup?
      We use revit most of the time, but for some work sketchup is a much better tool, but i wonder if there is good way to somehow connect the two programs as an altertive to work on two models.
      i have tried exporting as obj from revit and imported into sketchup using fluid obj import light, and it works fast and fine, but components / families gets exploded.
      i have then tried importing as dwg, and then using the groupbylayer plugin, but it takes forever to convert.....
      any tips for a good workflow?
      thanks
      jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • O Offline
        otb designworks
        You might try the IFC format. I've had fairly good luck with that. Bringing IFC into SU loses all the layer info, which is annoying, and I am not sure if Revit will see layers coming with a SU export, but it's worth a try, at least.
        The import into SU does retain all the component names applied in Revit, so that's good. None of the geometry gets exploded, either, which is also good
        Cheers, Chuck
        OTB Designworks is on Youtube
        • K Offline
          KrisM
          My best method is to export a dwg file from Revit but do a solid export. This keeps everthything grouped and exports to layers. There is still some cleanup to do but there is no perfect solution.
          • PixeroP Offline
            Pixero
            See my post here: https://sketchucation.com/forums/viewtopic.php?f=15&t=68000&hilit=+Revit
