Revit > sketchup - best workflow?
Is there any good tips for "connecting" revit and sketchup?
We use revit most of the time, but for some work sketchup is a much better tool, but i wonder if there is good way to somehow connect the two programs as an altertive to work on two models.
i have tried exporting as obj from revit and imported into sketchup using fluid obj import light, and it works fast and fine, but components / families gets exploded.
i have then tried importing as dwg, and then using the groupbylayer plugin, but it takes forever to convert.....
any tips for a good workflow?
thanks
jorgensen -
You might try the IFC format. I've had fairly good luck with that. Bringing IFC into SU loses all the layer info, which is annoying, and I am not sure if Revit will see layers coming with a SU export, but it's worth a try, at least.
The import into SU does retain all the component names applied in Revit, so that's good. None of the geometry gets exploded, either, which is also good
My best method is to export a dwg file from Revit but do a solid export. This keeps everthything grouped and exports to layers. There is still some cleanup to do but there is no perfect solution.
See my post here: https://sketchucation.com/forums/viewtopic.php?f=15&t=68000&hilit=+Revit
