    Model: lost in space
    8 Posts 4 Posters 2.7k Views 4 Watching
    • L
      lumenhorse
      Ok, this may sound silly, but I've lost my model amid panning, zooming and orbiting. All I have is a gray field with no reference to where the model is. How do I bring it back into view?
      • S
        shawb
        From the Camera dropdown menu select 'Zoom Extents' which should bring you back to your model. Hope this helps!
        • L
          lumenhorse
          Darn, I tried "Zoom Extents" to no avail... still just a vast field. On the upside, it's blue rather than gray now, so I know I'm above the horizon, somewhere in the stratosphere.
          • BoxB
            Attach the model so one of us can check it.
            • BoxB
              Is this it?
              I hit zoom extents, which strangely took me inside the model, I zoomed out until I could see it.
              The orbited around to a correct view. Noticed your Axes had be change so I reset them.
              And the Field of view was set to 1deg I changed that to the more standard 35deg.
              To be honest I can't tell you off hand what was wrong with your model apart from what I have described.
              I've had a bit more of a look at your model and you are using Layers incorrectly.
              All raw geometry must remain associated to Layer 0 only Groups and Components should be assigned a layer visibility tag.
              You can read up on it here.
              https://help.sketchup.com/en/article/3000122
              Ferguson Barn-play 2Box.skp
              • L
                lumenhorse
                Thanks, Box, for both finding my model and the great feedback! I'll check out that article.
                • L
                  lumenhorse
                  Here's the model... Hoping you can find it and, most important, tell me how to retrieve lost models in the future.
                  • david_hD
                    david_h
                    Darn. .I thought the topic was about this "Lost in Space" πŸ’š
                    Danger Will Robinson!
