    Model: lost in space
    8 Posts 4 Posters 2.3k Views 4 Watching
      lumenhorse
      Ok, this may sound silly, but I've lost my model amid panning, zooming and orbiting. All I have is a gray field with no reference to where the model is. How do I bring it back into view?
        shawb
        From the Camera dropdown menu select 'Zoom Extents' which should bring you back to your model. Hope this helps!
          lumenhorse
          Darn, I tried "Zoom Extents" to no avail... still just a vast field. On the upside, it's blue rather than gray now, so I know I'm above the horizon, somewhere in the stratosphere.
          • BoxB Offline
            Attach the model so one of us can check it.
            • BoxB Offline
              Is this it?
              I hit zoom extents, which strangely took me inside the model, I zoomed out until I could see it.
              The orbited around to a correct view. Noticed your Axes had be change so I reset them.
              And the Field of view was set to 1deg I changed that to the more standard 35deg.
              To be honest I can't tell you off hand what was wrong with your model apart from what I have described.
              I've had a bit more of a look at your model and you are using Layers incorrectly.
              All raw geometry must remain associated to Layer 0 only Groups and Components should be assigned a layer visibility tag.
              You can read up on it here.
              https://help.sketchup.com/en/article/3000122
              Ferguson Barn-play 2Box.skp
                lumenhorse
                Thanks, Box, for both finding my model and the great feedback! I'll check out that article.
                  lumenhorse
                  Here's the model... Hoping you can find it and, most important, tell me how to retrieve lost models in the future.
                  • david_hD Offline
                    david_h
                    Darn. .I thought the topic was about this "Lost in Space" πŸ’š
                    Danger Will Robinson!
