⌛ Sale Ending | 30% Off Profile Builder 4 ends 30th September
Selection to component
8 Posts 5 Posters 3.3k Views 5 Watching
  • P Offline
    Pixero
    I'm trying to group selected entitys and then convert it into a component to avoid SketchUp's component creation window.
    I have somehow made a wrong turn in my head and since this code doesn't give me an error in the console I'm not sure what I've messed up... 😳
    It's probably something embarassingly simple.
    ` mod = Sketchup.active_model
    ent = mod.entities
    	grp=[]
    	Sketchup.active_model.selection.each {|e|
    	  grp.push(e)
    	grp=ent.add_group
    	cmp=grp.to_component`
      slbaumgartner
      There are a couple of flaws in your code. First, you push Entities into the Array referenced by the variable grp and then immediately reassign grp to refer to your new Group. Second, you never added any content to the Group. The garbage collector in SketchUp Ruby is very aggressive about reaping empty Groups!
        rv1974
        TT already has (tt_groups2comps.rb) it for 100 years and it's perfect. I NEVER use the laggy standard one. Best works with shortcuts G for group, Shift-G for groups2comps
        http://sketchucation.com/forums/viewtopic.php?p=257578#p257578
          Try this:
          sel = mod.selection
          ent = mod.active_entities
          grp = ent.add_group(sel.to_a)
          dfn = grp.to_component
          dfn.name = "Compo#1"
          If you don't force a definition name, then the component is confusingly named "Group#NN"
          You must use .active_entities, because if the current selection is not in a matching entities context you'll BugSplat !
          • P Offline
            Pixero
            Thanks TIG.
            That worked very well.
            A short question though.
            In the Entitys info window the Instance is now called Compo and the Definition is called Group#1.
            I thought the definition would be called Compo?
              My mistake !
              Try this...
              sel = mod.selection
              ins = grp.to_component
              ins.definition.name = "Compo#1"
              The instance should remain 'un-named'...
              • P Offline
                Pixero
                Thanks again. This time it worked as it should.
                  db11
                  Thanks to both of you for a very useful code snippet. Especially helpful when you're making a component from loose geometry and forgot to check "Replace selection with component", and have to go through the process twice. Always good to save clicks and annoyances.
