    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    709 Posts 164 Posters 773.9k Views 164 Watching
      @derei said:
      My license shows all seats taken, but I am only using one. The other two must be from previous installations on my old machine. Any way to have them released? I contacted clothworks@sketchucation.com , but no response so far.
      Thanks.
      Check now
      • N Offline
        nilfae
        Hi! I formatted my computer and lost the plugin license file. How do I recover? Thank you!
        Nilson
        [Removed email]
        [mod=Rich:34fetzau]Do not publicize your email unless you like spam[/mod:34fetzau]
          If you visit https://sketchucation.com/webshop/my-licences.php can you see it?
            rv1974
            What setting(s) is responsible for preserving the cloth form after mouse movements?
            Currently the cloth looses desired form too fast to freeze the simulation.
            Say I'd like to get similar behavior:
            https://www.youtube.com/watch?v=7kszzf46lIU
              jerry8924564
              hi, can you release licenses on MyLicenses page , I can't release my licenses from MyLicenses page on Sketchucation.
              ID 10193
              thanks.
                Licenses released. You need to run Sketchucation Tools v4.2.9
                Sketchucation Tools | SketchUcation
                (sketchucation.com)
                on future installs to manage online releases
                  CLOESKOD1992
                  Hi!
                  I've added 30 pins across the length of a long cloth. When I press play, a lot of the pins are not attached to the cloth. It's a little random where some pins are attached and some aren't. I'm not sure what's going on, and haven't seen any posts about this. Wondering if anyone has encountered this or has any advice?
                  Thank you!
                  Cloe
                    It would be helpful if you share the .skp file so it can be examined.
                      Best practice is to pin at vertices...
                      https://i.imgur.com/GaV4zP6.png
                      ...as edges are ignored
                        ronmero
                        Excellent work! This is an incredible plugin. I can't figure out a way to create a round table cloth instead of a rectangle. Appreciate any assistance!
                        Thanks!
                          Thanks!
                          I'd start with a circle for the tablecloth.
                          • Y Offline
                            yatu
                            Hi Guys. I don't know what has happened, but recently my SketchUp keeps crashing the second I start a cloth simulation. Maybe two seconds in it crashes the latest. I don't know what I have changed to my system, other than doing a windows upgrade recently. Would anyone know what could be causing this or how to solve it`? I'm on the latest sketchup version 2022.
                            Thanks so much in advance and best regards!
                              What version of Windows are you using? Is it the Preview build?
                                Do you get a Bug Splat message when SketchUp closes?
                                Could be due to your Windows upgrade, especially if you are using Windows 11 Preview build. Could be due to graphics driver issues, possibly graphics drivers that don't support the Windows uild you are using. Could be due to incorrect installation of SketchUp. The correct method for installation requires right clicking on the downloaded installer and choosing Run as administrator.
                                What graphics card do you have?
                                I would anticipate that if you haven't got a legitimate license for Clothworks or you haven't correctly installed the license certain features wouldn't work but it wouldn't crash SketchUp.
                                Please update your forum profile to include SketchUp version and operating system version. That information helps us help you.
                                  Anton_S
                                  EDIT: I can get it to work very inconveniently like this: I need to make a clean reinstall of the plugin, and while I don't close SketchUp, the plugin will work normally. Once I reopen SketchUp, it keeps on crashing the second I start to simulate... do you think this is a licensing problem?
                                  Can you try a fresh install of sketchucationtools and clothworks? Please follow the steps in the installation manual: https://antonsynytsia.github.io/manuals/ClothWorks/installation_manual_v174.pdf
                                  Start from the Uninstallation Steps and then the Installation Steps.
                                  Let me know how it goes after performing these steps. I am not sure if this is ClothWorks or SketchUcationTools
                                  • Y Offline
                                    yatu
                                    Guys, thanks for the offered help! I'm currently away on vacation and will try your suggestions once more once I'm back. Anton, I was already on Windows 11 and did the official service update. And I already have tried the clean uninstallation / re-installation, which leads to clothworks working as it should - until I close Sketchup and reopen it, then it starts crashing.
                                    Dave, I don't get a bug splat window, it just closes immediately. I am running a legit Sketchup and clothworks license. If it was a windows / graphic driver related issue, I doubt I could get it to work after a fresh reinstall. I've got a RTX 3090.
                                    Thanks so far for your help, I'll keep you posted!
                                    cheers πŸ˜„
                                      Anton_S
                                      cheers πŸ˜„
                                      Thanks for the detailed feedback. I haven't personally tested ClothWorks on Windows 11. It's interesting that it only works on the first try. Suggests this may have to do with copying binaries versus loaded existing-copied binaries.
                                      • N Offline
                                        ngoctan0912
                                        Hi author. I am in Vietnam and I see that the technical community uses Sketchup in architectural design and other fields a lot, and at the same time I have noticed that people also use your ClothWorks Plugin. I have researched and aim to help people make good use of this Plugin in my country's technical community, as well as make your application more known. I would like to contribute a complete Vietnamese translation of the application. We look forward to your interest and will integrate this translation into the application in future updates.
                                        Thank you.
                                        • H Offline
                                          hank_hogan
                                          Hi Anton,
                                          I can also confirm that Clothworks plugin crashes SketchUp 2022 pro (without any bugsplat info) a moment after I press toggle play button to start cloth simulation. I have a powerfull laptop MSI GS66, so hardware shouldn't be an issue here. I have Win 11. Sketchup, sketchucation and clothworks plugins are up to date. I tried to unistall and reinstall clothworks according to Your guide and nothing changed. Even simple file with rectangle (cloth) and cylinder (collider) crashes right after simulation starts. Can you please help?
                                            Hmmm.... I'm not seeing this with SketchUp 2022. 6 or 7 year old computer with Nvidia GeForce 960.
                                            Click on the picture.
                                            What graphics card in your computer? Windows 10 or Windows 11?
                                            BTW, your profile indicates you are using 2017 Make. Please update your info. Thanks.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 32 / 36
