    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    704 Posts 162 Posters 687.8k Views 162 Watching
    • summerson1990S Offline
      summerson1990
      Just bought this plugin and saw a new version released (1.7.1a) but when updated the toggle UI interface is not working anymore. It can't be opened. I use SU 2019 PRO on win 10.
        summerson1990
        @anton_s said:
        Announcing version 1.7.1:
        1. Fixed crash on Mac OS X. Thanks to jkeller3 for the report.
        1. Added Spanish language. Thanks to Oxer for the translations.
        Hi! v1.7.1 and 1.7.0 toggle UI not working on SU 2019 PRO, Windows 10
          Anton_S
          The Toggle UI toolbar option works correctly on my system. Please do a clean installation of the plugin. Navigate to your plugins folder and delete ams_ClothWorks folder and ams_ClothWorks.rb file. Then do a clean installation of version 1.7.1.
          There are two plugin folders. To navigate to the first plugins folder, open a file explorer window and paste the following into the address bar: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
          The second plugins folder is located at:
          C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins
          Ensure that original version is deleted from both folders prior to installing the new version.
            summerson1990
            Maybe you are using not a last release of SU (2019.2)? Because I did exactly you adviced and still the problem exists... I can make a gif screenshot in order to prove it.
              This is what I see on 2019.2.
              Click on the picture to make it go.
                summerson1990
                [attachment=0:205mv7bc]<!-- ia0 -->UI Toggle.gif<!-- ia0 -->[/attachment:205mv7bc]
                Ok, so what's the problem with mine? See an attached gif by link https://dropmefiles.com/gDreG.
                  When you installed 2019.2, did you do so correctly? That is, did you right click on the downloaded installer and choose Run as administrator while logged into Windows under your normal user ID? We've seen lots of weird problems related to incorrect installation of SketchUp when users haven't used Run as administrator.
                    Anton_S
                    @summerson1990 I fixed the issue. Please update to 1.7.2. The problem had to do with non-ascii username. I originally relied on the ENV variable to get path to appdata. I see that the ENV variable has issues with non-ascii usernames. With 1.7.2, I updated to use Windows API to get the appdata path. Thank you for the report and my apologies for the inconvenience!
                      summerson1990
                      Yes, now it works fine, thanks a lot!)
                        jbf
                        Help needed...
                        I`m rather new to sketchup- I am playing around with Clothworks and I have ran in to a problem regards adding a pattern to the cloth. I have followed the instuctionvideo to the point- but the pattern breaks/cracks in the bendings (see pic.) what am I doing wrong? hoping someone can help me on the way- Thanks
                          Anton_S
                          @jbf You have to apply pattern (material) directly to the faces of the cloth. Do not apply material to the top level group. See one of the ClothWorks videos for applying material.
                            jbf
                            Thank you so much Anton- I canΒ΄t belive I overlooked that small detail. everything is working as it should πŸ‘
                            • kelly13K Offline
                              kelly13
                              Π’ скСтчапС ссылка Π½Π° Π»ΠΈΡ†Π΅Π½Π·ΠΈΡŽ ΠΏΡ€Π΅Π΄Π»Π°Π³Π°Π΅Ρ‚ ΠΊΡƒΠΏΠΈΡ‚ΡŒ Ρ‚ΠΎΠ»ΡŒΠΊΠΎ Ρ‡Π΅Ρ€Π΅Π· PayPal - Π° ΠΏΠ΅ΠΉΠΏΠ΅Π» Π·Π°Π±Π»ΠΎΠΊΠΈΡ€ΠΎΠ²Π°Π» ΠΌΠΎΠΉ счСт ΠΈ ΠΏΠΎΡ‚Ρ€Π΅Π±ΠΎΠ²Π°Π» ΠΏΡ€Π΅Π΄ΠΎΡΡ‚Π°Π²ΠΈΡ‚ΡŒ скан Π΄ΠΎΠΊΡƒΠΌΠ΅Π½Ρ‚Π°, ΡƒΠ΄ΠΎΡΡ‚ΠΎΠ²Π΅Ρ€ΡΡŽΡ‰Π΅Π³ΠΎ Π»ΠΈΡ‡Π½ΠΎΡΡ‚ΡŒ с Ρ„ΠΎΡ‚ΠΎ ΠΈ прописку, адрСс ΠΏΠΎ мСсту ΠΆΠΈΡ‚Π΅Π»ΡŒΡΡ‚Π²Π°. Π― ΠΆΠΈΠ²Ρƒ Π² строящСмся Π΄ΠΎΠΌΠ΅, ΠΊΠΎΡ‚ΠΎΡ€Ρ‹ΠΉ ΠΏΡ€ΠΈΠ½Π°Π΄Π»Π΅ΠΆΠΈΡ‚ ΠΌΠ½Π΅, Π½ΠΎ Ρƒ Π½Π΅Π³ΠΎ всС Π΅Ρ‰Π΅ Π½Π΅Ρ‚ ΠΎΡ„ΠΈΡ†ΠΈΠ°Π»ΡŒΠ½ΠΎΠ³ΠΎ адрСса ΠΈ поэтому Ρƒ мСня Π½Π΅Ρ‚ Π² паспортС прописки.
                              Π― прСдоставила сСрвису Paypal ΠΊΠ²ΠΈΡ‚Π°Π½Ρ†ΠΈΡŽ ΠΎΠ± ΠΎΠΏΠ»Π°Ρ‚Π΅ элСктроэнСргии с ΠΌΠΎΠ΅ΠΉ Ρ„Π°ΠΌΠΈΠ»ΠΈΠ΅ΠΉ ΠΈ адрСсом, Π½ΠΎ счСт ΠΌΠ½Π΅ Π΄ΠΎ сих ΠΏΠΎΡ€ Π½Π΅ Ρ€Π°Π·Π±Π»ΠΎΠΊΠΈΡ€ΠΎΠ²Π°Π½.
                              ΠžΡ‡Π΅Π½ΡŒ Ρ…ΠΎΡ‡Ρƒ ΠΊΡƒΠΏΠΈΡ‚ΡŒ Π²Π°ΡˆΡƒ Π»ΠΈΡ†Π΅Π½Π·ΠΈΡŽ, Π½Π΅ΡƒΠΆΠ΅Π»ΠΈ нСльзя ΠΏΠΎ-Π΄Ρ€ΡƒΠ³ΠΎΠΌΡƒ, НЕ Ρ‡Π΅Ρ€Π΅Π· PayPal ?
                              translated from Russian by Google translator
                              In the sketchup, the link to the license offers to be bought only through PayPal - and the paper blocked my account and demanded to provide a scan of an identity document with a photo and registration, address at the place of residence. I live in a house under construction, which belongs to me, but it still does not have an official address and therefore I do not have a residence permit in my passport.
                              I provided Paypal with a receipt for payment of electricity with my name and address, but my account has not yet been unblocked.
                              I really want to buy your license, is there really no other way, NOT through PayPal?
                                Anton_S
                                ЗдравствуйтС ЕвгСния! Π’Π°ΠΌ Π½Π΅ Π½ΡƒΠΆΠ΅Π½ PayPal для ΠΏΠΎΠΊΡƒΠΏΠΊΠΈ ClothWorks. НаТмитС Π½Π° ΠΊΠ½ΠΎΠΏΠΊΡƒ "Check Out", Ρ‡Ρ‚ΠΎΠ±Ρ‹ ΠΊΡƒΠΏΠΈΡ‚ΡŒ, ΠΈΡΠΏΠΎΠ»ΡŒΠ·ΡƒΡ Π΄Ρ€ΡƒΠ³ΠΎΠΉ ΠΌΠ΅Ρ‚ΠΎΠ΄. Π‘ΠΌΠΎΡ‚Ρ€ΠΈΡ‚Π΅ ΠΏΡ€ΠΈΠΊΡ€Π΅ΠΏΠ»Π΅Π½Π½Ρ‹Π΅ ΡΠΊΡ€ΠΈΠ½ΡˆΠΎΡ‚Ρ‹.
                                  chjblack1234
                                  ruby name is clothworks
                                  I bought a ruby. by the way, I wrote my email address wrong. What should I do? Who should I talk to?
                                  I'm so annoying now T.T
                                  • Gus RG Offline
                                    Gus R
                                    Anton,
                                    Upgraded to the recent release and I don't have the licensing problems I had last year.
                                    I am having difficulty reading the UI which appears to be a problem with other extensions on Sketchup. It appears to be using MSIE on my system.
                                    Is there a way to increase the size of the UI since I find it difficult to read? Zooming in doesn't work. I imagine it would require some tweaking of the UI.css or the html.
                                    This is what it looks like.
                                    www.instagram.com/gusrobatto/
                                    www.facebook.com/gusrobatto
                                    • Gus RG Offline
                                      Gus R
                                      Looks like I already answered my own question.
                                      I changed the "font family" line to "Arial" on the ui.css as such:
                                      font-family: "Arial", Helvetica, Arial, sans-serif;
                                      Then I increased the font sizes from 12px to 14px. It worked with 12px as well.
                                      Now it looks like this.
                                        Anton_S
                                        Thanks for the report and the solution, Gus R. I have only tested this with Windows 10 but I see that Windows 7, with an older version of IE, needs some CSS adjustments. Once again, thank you.
                                        • Gus RG Offline
                                          Gus R
                                          You're welcome Anton.
                                          It looks like it's un-validating itself again when I empty out my directory located at "C:\Users\Asus P8P67 Deluxe\AppData\Local\Temp."
                                          I'm able to validate the license again without losing any seats. I can keep Sketchup open and clear out the contents of the temp directory and I lose the validation. I re-validate and it creates a random directory with a .tmp file located there.
                                          Maybe the attached screenshot provides a hint?
                                            Anton_S
                                            Are you using the latest version of SketchUcationTools? By the way, I reset your seat count. It was full.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 35
                                            • 36
                                            • 21 / 36
