    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.6k Views 171 Watching
      Anton_S
      @summerson1990 said:
      Just bought this plugin and saw a new version released (1.7.1a) but when updated the toggle UI interface is not working anymore. It can't be opened. I use SU 2019 PRO on win 10.
      The Toggle UI toolbar option works correctly on my system. Please do a clean installation of the plugin. Navigate to your plugins folder and delete ams_ClothWorks folder and ams_ClothWorks.rb file. Then do a clean installation of version 1.7.1.
      There are two plugin folders. To navigate to the first plugins folder, open a file explorer window and paste the following into the address bar: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
      The second plugins folder is located at:
      C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins
      Ensure that original version is deleted from both folders prior to installing the new version.
      • summerson1990S
        summerson1990
        Maybe you are using not a last release of SU (2019.2)? Because I did exactly you adviced and still the problem exists... I can make a gif screenshot in order to prove it.
          This is what I see on 2019.2.
          Click on the picture to make it go.
          • summerson1990S
            summerson1990
            [attachment=0:205mv7bc]<!-- ia0 -->UI Toggle.gif<!-- ia0 -->[/attachment:205mv7bc]
            Ok, so what's the problem with mine? See an attached gif by link https://dropmefiles.com/gDreG.
              When you installed 2019.2, did you do so correctly? That is, did you right click on the downloaded installer and choose Run as administrator while logged into Windows under your normal user ID? We've seen lots of weird problems related to incorrect installation of SketchUp when users haven't used Run as administrator.
                Anton_S
                @summerson1990 I fixed the issue. Please update to 1.7.2. The problem had to do with non-ascii username. I originally relied on the ENV variable to get path to appdata. I see that the ENV variable has issues with non-ascii usernames. With 1.7.2, I updated to use Windows API to get the appdata path. Thank you for the report and my apologies for the inconvenience!
                • summerson1990S
                  summerson1990
                  Yes, now it works fine, thanks a lot!)
                    jbf
                    Help needed...
                    I`m rather new to sketchup- I am playing around with Clothworks and I have ran in to a problem regards adding a pattern to the cloth. I have followed the instuctionvideo to the point- but the pattern breaks/cracks in the bendings (see pic.) what am I doing wrong? hoping someone can help me on the way- Thanks
                      Anton_S
                      @jbf You have to apply pattern (material) directly to the faces of the cloth. Do not apply material to the top level group. See one of the ClothWorks videos for applying material.
                        jbf
                        Thank you so much Anton- I can´t belive I overlooked that small detail. everything is working as it should 👍
                        • kelly13K
                          kelly13
                          В скетчапе ссылка на лицензию предлагает купить только через PayPal - а пейпел заблокировал мой счет и потребовал предоставить скан документа, удостоверяющего личность с фото и прописку, адрес по месту жительства. Я живу в строящемся доме, который принадлежит мне, но у него все еще нет официального адреса и поэтому у меня нет в паспорте прописки.
                          Я предоставила сервису Paypal квитанцию об оплате электроэнергии с моей фамилией и адресом, но счет мне до сих пор не разблокирован.
                          Очень хочу купить вашу лицензию, неужели нельзя по-другому, НЕ через PayPal ?
                          translated from Russian by Google translator
                          In the sketchup, the link to the license offers to be bought only through PayPal - and the paper blocked my account and demanded to provide a scan of an identity document with a photo and registration, address at the place of residence. I live in a house under construction, which belongs to me, but it still does not have an official address and therefore I do not have a residence permit in my passport.
                          I provided Paypal with a receipt for payment of electricity with my name and address, but my account has not yet been unblocked.
                          I really want to buy your license, is there really no other way, NOT through PayPal?
                            Anton_S
                            Здравствуйте Евгения! Вам не нужен PayPal для покупки ClothWorks. Нажмите на кнопку "Check Out", чтобы купить, используя другой метод. Смотрите прикрепленные скриншоты.
                            • C
                              chjblack1234
                              ruby name is clothworks
                              I bought a ruby. by the way, I wrote my email address wrong. What should I do? Who should I talk to?
                              I'm so annoying now T.T
                              • Gus RG
                                Gus R
                                Anton,
                                Upgraded to the recent release and I don't have the licensing problems I had last year.
                                I am having difficulty reading the UI which appears to be a problem with other extensions on Sketchup. It appears to be using MSIE on my system.
                                Is there a way to increase the size of the UI since I find it difficult to read? Zooming in doesn't work. I imagine it would require some tweaking of the UI.css or the html.
                                This is what it looks like.
                                www.instagram.com/gusrobatto/
                                www.facebook.com/gusrobatto
                                • Gus RG
                                  Gus R
                                  Looks like I already answered my own question.
                                  I changed the "font family" line to "Arial" on the ui.css as such:
                                  font-family: "Arial", Helvetica, Arial, sans-serif;
                                  Then I increased the font sizes from 12px to 14px. It worked with 12px as well.
                                  Now it looks like this.
                                    Anton_S
                                    Thanks for the report and the solution, Gus R. I have only tested this with Windows 10 but I see that Windows 7, with an older version of IE, needs some CSS adjustments. Once again, thank you.
                                    • Gus RG
                                      Gus R
                                      You're welcome Anton.
                                      It looks like it's un-validating itself again when I empty out my directory located at "C:\Users\Asus P8P67 Deluxe\AppData\Local\Temp."
                                      I'm able to validate the license again without losing any seats. I can keep Sketchup open and clear out the contents of the temp directory and I lose the validation. I re-validate and it creates a random directory with a .tmp file located there.
                                      Maybe the attached screenshot provides a hint?
                                        Anton_S
                                        Are you using the latest version of SketchUcationTools? By the way, I reset your seat count. It was full.
                                        • Gus RG
                                          Gus R
                                          Updated SketchUcationTools and reinstalled from there. Same thing. Looks like now it's deducting from seat counts with only 2 left.
                                          Seats: Max = 3 - Taken = 1 - Left = 2
                                          It's the same like last time where it creates a .tmp file in the temp directory.
                                          I'm wondering if I should try installing it in "C:\ProgramData\SketchUp\SketchUp 2017."
                                            Anton_S
                                            Hmm... I am not sure what is going on. Is it necessary to clear the temp folder?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 36
                                            • 37
                                            • 21 / 37
