    Cuda error 719
    renderpluginsextensions
    2 Posts 2 Posters 2.8k Views 2 Watching
    • F Offline
      Fahadalhedar
      Hello everyone!
      Im using vray 3.4 on sketchup 2017. When i try to render a small object with little details using CPU,it works great. I wanted to try rendering using the gpu acceleration feature and it keeps giving me this cuda error code 719.
      I tested rendering with gpu put setting super low resolution and it worked. But if i set it to 1920x1080 it stops again and same error code.
      First thing came to my mind is that it might be a driver issue but everything is up to date.
      I tried searching for this everywhere and i couldnt solve it.
      Pc specs:
      i7 -7800x
      Geoforce gtx 1080 ti
      Please help me with this because i got so many projects needed to be rendered and i know gpu renderingnis faster than thr cpu.
      Thanks!
        DLad
        Hi Fahadalhedar,
        any succes with this?
        Its litterly, my current issue.
