    Help - Can’t get solid correct.
    8 Posts 2 Posters 3.1k Views 2 Watching
    • C
      caymanquad
      Hello,
      I have a sketch up model I made using Curviloft and sketch up pro 2017.
      I am trying to get a single solid by combing two separate solids.
      Each solid is neat and tidy according to solid inspector 2, but when I try to combine them I keep getting errors and I can’t figure out what is wrong. I think it’s an interface issue.
      The model is already scaled up 10x, so it shouldn’t be a size thing.
      Is there anyone that would be willing to check out my model for me if I upload it?
      Thanks kindly,
      Adam
      • BoxB
        Well unless you attach it we can't really help, so attach away.
        • C
          caymanquad
          Hi Thanks,
          I've attached both 2017/2013 versions. This is supposed to be similar to a hollow cylinder with a solid bottom (like a tall glass), except it has complex inner outer surfaces that were generated in between the two ends.
          The weird thing is that i have two manifold/watertight solids, but i can't seem to get them to combine into one nice solid!!! Very frustrating. Any help would be appreciated, or some tips on how I can do this myself. (This is my first try at complex geometry, so your methodology for finding my issues and interpreting errors would be appreciated)
          Other info:
          -Model is scaled by 10x already
          -I used curviloft twice to make the 'inner' and 'outer' wall surfaces of the main body between two end profiles. Then I used 'solidsolver' to make the mainbody into a solid group. This worked well and the main body shows as a solid group (clean and tidy per solidinspector2)
          -When using curviloft i used bezier method 2
          -The end cap is grouped and shows as a solid group (clean and tidy per solidinspector2)
          Thanks for any assistance!
          -Adam
          SU2017 Version
          SU 2013 Version
          • BoxB
            Problem you have is the number of segments in the circles don't match.
            The outer ring of the 'Vessel' and the outer ring of the 'Cap' need to match for it to join properly.
            So I took a slice through the cap and used it as the profile and the outer ring as the path for Follow me.
            You could scale up more than 10x in future, especially with such a high segment count and remember to use consistent segmentation.
            Combine_two_Box.skp
            • C
              caymanquad
              Awesome, thanks so much. I will take a look at this later today!
              Much appreciated.
              -Adam
              • C
                caymanquad
                The model looks really good, thanks for the tip about the equal number of segments...didn't even think of that. For my information, what did you do to get a solid after you finished the 'follow me' for the solid cap? Did you use a plugin, or just group the two solids?
                One other question - i noticed that you were also able to get rid of the profile line that was in the center portion of the main body solid (the profile with a keyhole). Did that just happen automatically when you converted the whole model to a solid, or did you do something to get rid of it?
                Thanks again, very helpful and I definitely learned of a better way to close off a complex solid geometry (follow me)!
                -Adam
                • BoxB
                  No plugins or fancy tricks, just vanilla sketchup.
                  I used the Dave Method https://sketchucation.com/forums/viewtopic.php?f=18&t=68150 because doing it at the size you have it leaves some holes in the follow me.
                  I made a slice of the cap, positioned it then cut and pasted it into the keyhole group directly. Follow me to create the shape then a section plane to look inside and trace over one segment to reform the inner face. Finish of with the soften/Smooth tool to remove the extraneous surface lines. Then delete the large one and you are left with a small one with all edits intact.
                  (you won't find copy and paste in place in the context menu like I have here, but in the Edit menu.)
                  https://i.imgur.com/p18j2mq.gif
                  • C
                    caymanquad
                    Thanks so much Box, very helpful! This will help me with a bunch of stuff!
