    Troubles converting into a Solid
    4 Posts 3 Posters 9.9k Views 3 Watching
      lmtsketch
      I an unable to convert my model into a solid. I have attempted several different methods without success. I have crashed Sketchup Pro 2018 several times in the process. Is this model salvageable? I have tried Cleanup3, SolidSolver, and Solid Inspector 2. Thanks
      Globe_Slice_Check.skp
        lmtsketch
        I have recreated this model and I am creating a new post.
          So your problem is solved ?
          If not post your model in V6 (if possible) for a more large audience!
          • ecatiE Offline
            ecati
            This section is very complex. Is there an object or picture you have sampled for drawing this section?
            Rather than correcting this model, it will be easier to redraw. However, it must be ensured that each piece is solid when redrawn.
