My way to put a A0 plan in SU
Hello
I explain this method because I did not find any precize answer, an it may help somebody.SU PARAMETERS
- With use maximum texture size, you can go up to 4096*4096 with a good graphic card
PREPARING IMAGE
- coming from PDF, you can go from PDF with Photoshop to jpg, and save in 300dpi
- coming from DXF, you can use Inscape, but job is a little more painful
CUTTING IN IDENTICAL PIECES
- with photoshop (affichage, magnetisme, tranche) you get (selection de tranche)
- with right mouse you choose horizontal 3, vertical 4
- save to the web: you have your identical pieces in jpg
IMPORT IN SU
- first square OK, align all other to that one, compose the page
- get the highest dimension to scale
I get less than 0.001 error
It takes a quarter of an hour
Good luck
Marc
Register LoginAdvertisement
