    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Automatic alignment - how to?
    7 Posts 3 Posters 957 Views 3 Watching
    • HornOxxH Offline
      HornOxx
      Hi - I need a tip
      is there a possibility to position components (or groups) directly next to each other on their component frame automatically? (something like you can see below)
      never trust a skinny cook
      • BoxB Offline
        Have a look at Align and Distribute from S.D.Mitch
        http://sdmitch.blogspot.com.au/
        • HornOxxH Offline
          HornOxx
          Thanks Box !!!! πŸ‘ a perfect plugin solution - exactly what I was looking for. Only - I can't get it to run (SkUp 2016 Pro / Win10) so far...
          • HornOxxH Offline
            HornOxx
            got it 😳 - I need glasses - thank you very much again! πŸ˜„
            • HornOxxH Offline
              HornOxx
              thanks Pilou - somehow I have missed all these ingenious toolsets πŸ˜„
              although Box's recommendation was an exact hit in my actually case, I will try out your tip also because theses tips always give great solution options for future tasks ...
              Best
                Or more funny the Component random replacement always by Sdmitch!
                Advantages :
                you can make without random so your wish above but also random!
                But the big one is that you can make that on any curves! πŸ˜„
                (just put "Targets" component as you want on a 3D curve(s) a simple component "x" is sufficient )
                  A very versatile tool indeed!
                  Just a little trick : all Targets must be a same copy component else Source(s) don't follow the different target's orientations!
                  I believe in this one you have Relative size or not! πŸ˜‰
                  ComponentReplace.zip
