    MSphysics Need help with action
    extensions
    10 Posts 2 Posters 2.6k Views 2 Watching
      Larry3141
      How do I make the cylinder stay in side the wheel when it turns? Would like cylinder to roll in the slot as the wheel rotates.
      have tried lots of shapes, nothing I have tried has worked.
      Thanks, Larry
      wheel
      • ecatiE Offline
        ecati
        Would you share the skp file, please.
          Larry3141
          Thank you for the answer, here is the file....Larry
          wheel action v1.skp
          • ecatiE Offline
            ecati
            Follow these steps.
            • ecatiE Offline
              ecati
              Click on the 3. picture.
              I hope this is what you want.
              • ecatiE Offline
                ecati
                Here is the skp file.
                wheel action v1_ecati.skp
                  Larry3141
                  Very good. Can you contact me please (see file name.), I am not sure how to describe how I need for this to act. I added to your file but I can't get it to work right. I must be over looking something.
                  Thank you very much for your work, LEE
                  wheel action v1_ecati_LEE_615_969_0688.skp
                  • ecatiE Offline
                    ecati
                    1. The engine connection must be at the center of the wheel, not away.
                    2. Some settings should be as I do.
                    3. If you ask this question "http://sketchucation.com/forums/viewtopic.php?f=323&t=64521&start=60" you can get better solutions.
                    wheel action v1_ecati1.skp
                      Larry3141
                      Thanks, I slowed the rotation and it works. How do I make the cylinder fall back into the slot at the top position as it rotates? Does it have something to do with centrifugal force?
                      I very much appreciate your help, Larry
                      • ecatiE Offline
                        ecati
                        In my opinion, it is from the centrifugal force.
                        I can not help you with this because I do not have top level knowledge. If you ask this question "http://sketchucation.com/forums/viewtopic.php?f=323&t=64521&start=60" you can get better information.
