MSphysics Need help with action
How do I make the cylinder stay in side the wheel when it turns? Would like cylinder to roll in the slot as the wheel rotates.
have tried lots of shapes, nothing I have tried has worked.
Thanks, Larry
Would you share the skp file, please.
Follow these steps.
Click on the 3. picture.
I hope this is what you want. -
Very good. Can you contact me please (see file name.), I am not sure how to describe how I need for this to act. I added to your file but I can't get it to work right. I must be over looking something.
Thank you very much for your work, LEE
- The engine connection must be at the center of the wheel, not away.
- Some settings should be as I do.
- If you ask this question "http://sketchucation.com/forums/viewtopic.php?f=323&t=64521&start=60" you can get better solutions.
Thanks, I slowed the rotation and it works. How do I make the cylinder fall back into the slot at the top position as it rotates? Does it have something to do with centrifugal force?
I very much appreciate your help, Larry
In my opinion, it is from the centrifugal force.
I can not help you with this because I do not have top level knowledge. If you ask this question "http://sketchucation.com/forums/viewtopic.php?f=323&t=64521&start=60" you can get better information.
