    Attaching arbitrary data to a model
    5 Posts 3 Posters 3.2k Views 3 Watching
      B2Pi
      Is there a way to attach what was once called a blob to a model? Perhaps I'm blind, but I'm just not seeing it. If not, is there some other magic method to accomplish something similar?
      Cheers
      • TIGT Online
        model.set_attribute('MyLovelyBlob', 'some_key', value)
        To read that key use:
        val = model.get_attribute('MyLovelyBlob', 'some_key', nil)
        Returns nil if not set.
        The value can be integer/float/length/string/boolean/array [array of any of the other types]
        Attributes can be set/got for most kinds of things in SketchUp - from the model itself down through collections and entities...
          slbaumgartner
          I interpret "blob" to mean "binary large object", that is, a sizeable chunk of otherwise opaque binary data. You might need to pack your blob into a Ruby type that set/get_attribute handles correctly. Test with specific examples to see whether what you have survives the round trip or needs to be packed.
          • TIGT Online
            If the 'blob' is actually binary data you can convert it with ruby into a string for the set_..., then convert it back to binary after the string is returned by the get...
            There is a length limit for a single string attribute [~20000]...
            Before the API introduced the ability to download a SKP [binary-file] from a URL, in the oldie system I invented a temporary fix using the then API, to allow you to do it by downloading/inserting a remote almost empty [binary] SKP and then extracting its special string attribute[s] and reworking them back into binary data - concatenating multiple strings into one if the max length was exceeded.
            You then had an RBZ to install...
            RBZ2SKP [note: some references etc need setting initially !]
            		defn = model.definitions.add(File.basename(path)) ### make defn [if needed]
            		defn.entities.add_cpoint([0,0,1]) ### so NOT empty
            		data = File.open(path, "rb"){|io| io.read}.unpack('H*')[0]
            		  ### tidy up in case observers have added stuff ?
            		  defn.attribute_dictionaries.each{|attd|
            			attd.keys.each{|k| attd.delete_key(k) }
            			defn.attribute_dictionaries.delete(attd)
            		  } if defn.attribute_dictionaries
            		  ### divide up
            		  key = 'x0001'
            		  chunk = 20000 ### size limit
            		  start = 0
            		  parts = data.length / chunk
            		  (parts + 1).times{
            			part = data[start..(start+chunk)]
            			defn.set_attribute("RBZdata", key, part)
            			start = start + chunk + 1
            			key.next!
            		### save as SKP
            		nname = File.basename(path).gsub(/^[^A-Za-z0-9._-]/, '').gsub(/[^A-Za-z0-9._-]/, '_') + '.skp'
            		### strip out leading # and all non A0Z etc as '_'
            		skp = File.join(File.dirname(path), nname)
            		defn.save_as(skp)
            		defn.entities.clear!
            SKP2RBZ [note again: you'll need to define some references and decide on the exact code !]
            		### after the SKP is added...
            		defn = model.definitions[-1]
            		return false unless defn
            		### reassemble
            		attd = defn.attribute_dictionaries['RBZdata']
            		return unless attd
            		data = ''
            		attd.keys.sort.each{|key|
            			data << defn.get_attribute('RBZdata', key, '')
            		datax = [data].pack('H*')
            		fi = File.open(path,'wb')
            		  fi.write(datax)
            		fi.close
            		@model.start_operation('SKP2RBZ')
            		  Sketchup.send_action("editUndo;")
            		@model.commit_operation
            You might be able to extract a 'blob' set/get from this...
              B2Pi
              Please forgive me. I was convinced that I'd already replied. This is exactly what I needed (and I'm further at a loss wrt how I didn't see that in the the API reference). Thanks very much
