    Problem with scene/image resizing when converting to vector
    layout
    2 Posts 2 Posters 3.0k Views 2 Watching
    • J
      Jvenning
      Hi ,
      I have been using sketchup and layout for a while , making section cuts from sketchup models using the 'section cut face' plugin and then importing into layout, a raster and vector version of a scene so that I can have good cut lines overlayed as vectors over a raster scene/image. I have had no issues in the past but now suddenly when I alter the properties of the section lines from a raster to a vector in order to overlay, the image resizes and becomes huge so that it is much larger than the raster version of the scene below , I cannot see why this is happening. I have tried deleting the scenes and cut face and starting again and it still happens, what's more it only occurs on one axis, when I take sections perpendicular I have no issue.
        Could you share the LO file it is happening in? If not publicly, by private message?
