    Animation ACT camera positionning plugin?
    3 Posts 3 Posters 1.2k Views 3 Watching
    • P
      phdotone
      **Hi,
      Happy New Year All
      Can anyone direct me to a Sketchup plugin that will create and place an ACT camera at regular intervals along a polyline to make setting up a fly through animation a little easier? Ideally with control over direction of view ie parallel to the geometry of the polyline at the point of insertion.
      Or maybe a technique using a couple of different plugins
      Thanks in advance
      Phil Mellor
      Sketchup Pro 18**
      • D
        DaBouncer
        I'm also interested in something like this; trying to animate a camera along a Zipline (catenary); using scenes does not look that good... πŸ˜•
        Did you find a working solution?
        • F
          faust07
          Examples of camera simulations with MSphysics can be found here:
          http://sketchucation.com/forums/viewtopic.php?f=323&t=68975
          You can connect a target object with the same polyline/curve (Curvy Piston) in front of the camera object to get a parallel view.
