Animation ACT camera positionning plugin?
**Hi,
Happy New Year AllCan anyone direct me to a Sketchup plugin that will create and place an ACT camera at regular intervals along a polyline to make setting up a fly through animation a little easier? Ideally with control over direction of view ie parallel to the geometry of the polyline at the point of insertion.
Or maybe a technique using a couple of different plugins
Thanks in advance
Phil Mellor
Sketchup Pro 18**
I'm also interested in something like this; trying to animate a camera along a Zipline (catenary); using scenes does not look that good...
Did you find a working solution?
Examples of camera simulations with MSphysics can be found here:
http://sketchucation.com/forums/viewtopic.php?f=323&t=68975
You can connect a target object with the same polyline/curve (Curvy Piston) in front of the camera object to get a parallel view.
