    Place a shape on a curved shape
    10 Posts 2 Posters 6.2k Views 2 Watching
      selinav42
      Hello,
      I would like to know how to realize the body of pineapple seen on https://www.thingiverse.com/thing:2510361
      I was thinking of making a pyramidal shape that I would place on an oval shape.
      How to do it?
      What is the other method otherwise?
      Thanks in advance
      • N Offline
        nlipovac
        Try with this plugin...
        https://sketchucation.com/plugin/1406-flowify
          selinav42
          thank finally I've succeed to make a pipe with the plugin fredoscale (4 quarter of cycle) but now I do not know how to reduce the top and bottom diameter to get the body of the pineapple
          https://image.noelshack.com/fichiers/2017/52/4/1514474904-pineapple.jpg
          If I take the resize tool small pyramids are too distorted on the line after selection.
          https://image.noelshack.com/fichiers/2017/52/4/1514475129-pineapple2.jpg
          How can I do to have a resizing on selected lines?
          Thanks for your help
          • N Offline
            nlipovac
            Hi, Fredo scale does have taper scale so see if you can use that for scale.
            Here is a file I created using Flowify plugin.
            https://www.youtube.com/watch?v=STDljROiq1k&t=443s
            Flowify plugin
            Flowify plugin
              selinav42
              Finally I succeed with shape bender. In 3 times.
              • First, I have tilt the shape to have an ovale shape
              • Then, I have round with 1/2 circle
              • I copy the shape obtain to have the whole pineapple
              I've tested with flowify without success. I've followed a youtube video but, when I test the example nothing happend...
              Thank you for your help and the file.
              I print now.
              • N Offline
                nlipovac
                Cool, post a pic of the finished print. πŸ‘ 😎
                  selinav42
                  I test with your file with flowify and I can't have a result.
                  Can you give me the process to follow please ?
                  I have traced a 1/2 cylinder on the back of pyramids shape (does dimension have an impact ?)
                  Put lines on each side to connect half cylinder with pyramids shape
                  Flowify but I get an error message
                  "Input error : can't not find support groupe.The support group must contain 3 further groups and one of these groups must contain two connection edges".
                  I have 3 groups :
                  • my pyramids shape
                  • my two connections
                  • my half cylinder
                  Do you have an idea ?
                  • N Offline
                    nlipovac
                    You need three support groups:
                    • That 1/2 of cylinder is first
                    • Projection plane is second
                    • Connecting edges are third
                      You need to group them each and all together. See how mine is grouped.
                      You place geometry you want to lay down onto cylinder on a projection plane.
                      Then you use Flowy.
                    Maybe this video can explain it better than the last one I posted.
                    https://www.youtube.com/watch?v=_c76j5NNkhM
                    • N Offline
                      nlipovac
                      Here are steps I used in form of SU file.
                      Ananas_v1-1.skp
                        selinav42
                        ok, thank you for your file.
                        I have understand.I succeed to use flowify with your example.
                        I was trying to place directly my pattern on the half cylinder, that's why it didn't work.
                        Thanks for all
