    Need a leg up.
    7 Posts 2 Posters 9.9k Views 2 Watching
    • L
      This was sorted thanks to Box.......Thanks Box πŸ‘
      • BoxB
        If you attach the model we call tell you if it is printable or how it needs to be corrected.
        • L
          Thanks Box, that is very generous! Problem is i designed the lamp for moulding and laying in carbon fibre ( its only an easthetic skin) so I will have to start affresh. I will start to model somthing conceptual now. will take a couple of hours. Will get it to you ASAP
          • BoxB
            Wouldn't the model just be the void of the mold you created?
            • L
              I need to think about how trap the "lamp" (a 200x50x0.5mm flexable oled) and how the "head" will be affixed to the Carbon fibre "rod" or more correctly "tube"
              • L
                Concept lamp 1.skpHi Box, have attached a sketch model. it is just loose ATM but just to give you an idea.
                I have not given thickness to the main body but it wiould need ti be very thin as wieght is everything in this project. I have also notdone the bottom bit that would entrap the lamp.
                • L
                  Oh it is scaled up by a factor of 10
