    Wacom - SketchUp - double click problem.
    2 Posts 2 Posters 1.4k Views 2 Watching
    • C
      chrisyamao
      Hi, this is my first time posting in this forum. I've searched for an answer for my problem all around, and found nothing.
      I've been using SketchUp 2016 and 2017 (Make) in my Macbook pro, using a wacom intuos pro with no problems.
      But now, all of a sudden, whenever i try to pan, orbit, or zoom rapidly using my wacom pen, SketchUp will interpret it as a double click, instead of me clicking and dragging to orbit or pan around. (Causing the model to CENTER instead of following the dragging i want to do)
      I tried a different Wacoms and the problem persists
      I tried different computers and the problem persists.
      I tried using the trackpad or a mouse and the problem is gone, but i'm much faster in my work using a wacom pen.
      I have no problems in any other software. I use Adobe software and the macOS perfectly and in no occasion a quick click and drag gets interpreted as a double click.
      The problem seems to be with the Wacom, SketchUp, and the double click command.
        What is the button's assignment in the Wacom control panel? Did you recently upgrade the drivers? If it had been working well before and just suddenly stopped, you need to look at what has changed. SketchUp didn't change--they don't send out automatic updates like Apple does, for example--so you should look elsewhere.
        Did you update the OS version recently? What version are you running?
