    Problem with My Spreadsheet Help?
    17 Posts 2 Posters 3.5k Views 2 Watching
    • Joe WoodJ Offline
      Joe Wood
      Maybe it isn't an Excel issue either because I've tried opening my spreadsheet with Open Office and Libre Office. O Office just freezes, and excel and libre I see those #VALUE!
      So all three spreadsheet programs aren't working on any of my 100s of spreadsheet files. Are all my S sheet files corrupted now? I've asked over at the Microsoft and open office forums but no help there
      Someone made this s sheet for me (I don't know how to code) 10+ years ago and it's been working fine up until now.
      Joe Wood
      woodsshop.com/
      • Joe WoodJ Offline
        Joe Wood
        Could someone take a look at the s sheet and see if it works for you??
        France Curved Azumaya.xls
        Joe Wood
        woodsshop.com/
        • K Offline
          KrisM
          Joe,
          Works fine for me. Excel 2010.
          Here's a note from the help file -
          How to correct a #VALUE! error
          Excel shows the #VALUE! error when your formula includes cells that have different data types (text and numeric values). The #VALUE! error is also shown when a formula references one or more cells that have text instead of numbers, and uses the standard math operators (+, -, *, and /) to add, subtract, multiply, or divide the different data types.
          KrisM
          • K Offline
            KrisM
            Actually, it doesn't work. Excel was doing something for a web imported file which made it look like it was working.
            The Quantity column has no entries. If you put a number in it, the #value disappears.
            KrisM
            • Joe WoodJ Offline
              Joe Wood
              Yeah that was an o office file I renamed as xls which didn't work so well,
              it does come up with a number putting in a quantity, but that doesn't show up down in the Total line.
              here's the actual xls file.
              so why could all of my s sheet files suddenly become corrupted / whatever? Can't work with then using any of the 3 S sheet programs?
              Joe Wood
              woodsshop.com/
              • K Offline
                KrisM
                I can't comment on what happened to the files. Were they made in an old version of excel or some other spreadsheet program? There may be a conversion issue.
                If you look at each formula in the @value cells, the referenced cells seem to have a "general" format. If you change that to a "number" format, then the formulas work. If that doesn't work, I selected the referenced cell and hit delete. Even though the cell is blank, this seems to correct things.
                • Joe WoodJ Offline
                  Joe Wood
                  It was made over 10 years ago, but I've been using it up until about 5 days ago using Open Office. I just tried Excel yesterday and saw it doesn't work either.
                  darn I don't really know what each of those cells you named are.
                  where could I go to get help with this, my local repair shop or is there somewhere online? Need to get this corrected soon!
                  Joe Wood
                  woodsshop.com/
                  • K Offline
                    KrisM
                    Joe,
                    Fixed it. Ask your local repair guy about an Excel person local to you. They could explain it all firsthand. Basically it has to do with your spreadsheet programs thinking some number are not numbers but letters. As to why this has happened, I don't have a clue. Aren't computers great?
                    KrisM
                    France Curved Azumaya-1.xls
                    • Joe WoodJ Offline
                      Joe Wood
                      I'll check it out in the AM Kris,
                      I see you're a timber frame designer πŸ™‚ That's something I've never really done is any serious timber framing.
                      Joe Wood
                      woodsshop.com/
                      • Joe WoodJ Offline
                        Joe Wood
                        Right on Kris, you fixed it πŸ™‚ Gracias amigo! What did you do, edit all the cells??
                        top right, what is that Result 'Bad' in the red box? I've never seen that before.
                        Joe Wood
                        woodsshop.com/
                        • K Offline
                          KrisM
                          Joe,
                          Glad it works. Here's an explanation of what I did. The #value error message says that the formula is referencing cells which don't have the appropriate format. Using row 14 as an example, if you click on the cell at I14 (column I and row 14), you will see up at the top of the screen that this cell contains a formula which in this case is multiply the contents of cell E14 with the contents of cell G14. If we look at G14, we see it contains '6', a number. Cell E14 is seemingly blank. If we right click on e14 and look at the format setting, it is shown as general. This means that it can contain either text or numbers. When excel wants to use this cell in a multiplication operation as required by the formula and the cell is seemingly empty, it doesn't know what to do and gives the error message. What I did was delete the cell contents with the delete key which allowed excel to reevaluate what it wanted in that cell which it set to being a number. The cell was acting like it contained a space (a letter which you can't see). An alternate method is to type a 0 (zero) into every cell which is referenced by a formula which sets the quantity and establishes the cell as containing a number. I've attached the spreadsheet with 0's inserted everywhere that a quantity is required. Having blank cells is a bit confusing. Better practice is to have an entry in any cell which contains a number, even if that number is 0. Hope that makes sense.
                          The red box is displaying a setting that you can use if you want to apply a particular look to a cell (colour, text size, underline etc.). This is a setting that you can copy using the paint brush icon onto a cell that you want to look like that. Not really something you necessarily need.
                          You might find it useful to take a short excel course at your local college or wherever it is offered close to you. Excel is in fact quite simple and I am quite sure that you would pick it up quickly. Speaking from my own software experiences, I had to learn a new timber software which had me totally befuddled. After I was shown a few things about how it worked, it was in fact dead simple to use. Good to send your brain in a different direction once in a while.
                          Speaking of your timber frame skills, I would say that looking at your work, that your skillset is right up there. πŸ˜„
                          KrisM
                          France Curved Azumaya-2.xls
                          • Joe WoodJ Offline
                            Joe Wood
                            Right on x 2 Kris! Now I can work on an estimate for one of my azumaya kits going to Cannes France πŸ™‚ Thanks for taking the time with this for me!
                            matter of fact, could I ask about how you'd do a post to beam connection using T framing??
                            this is how I usually do it using 6x8 posts and 4x beams for my azumaya which are fairly small buildings.
                            this one to France will be a larger building and I just know I need a better post connection, and in France they have a long tradition of T framing and they don't want to see any fasteners!
                            Joe Wood
                            woodsshop.com/
                            • Joe WoodJ Offline
                              Joe Wood
                              This is the building Kris, around 20' x 14'.
                              Joe Wood
                              woodsshop.com/
                              • K Offline
                                KrisM
                                Joe,
                                Here's one way to do it. Same half lap but the mating surfaces are on a bevel so that the weight from above locks the corner together. Put three timber screws through the beams (plates in timber frame parlance) down into the post. Two more timber screws from the bit of the post sticking up into the sides of the beams. Countersink and plug those two screws. The fact is that the timber frame industry in Europe has invented and uses a lot of metal products to make their industry more cost efficient. For example, the timber screws we now see came from products created in Europe. If you really want the whole meal deal, you could put the ends of the braces into a 3/4" deep housing and then also have a mortise & tenon connection with a peg. Authentic and strong. Also more labour intensive and costly than what you have drawn.
                                KrisM
                                Joe - France V8.skp
                                • Joe WoodJ Offline
                                  Joe Wood
                                  I've thought about doing something like that Kris but not sure how i'd make those angled cuts. My normal way is using my radial arm saw and dado blade.
                                  so you know much about the metal products / connectors used in France?
                                  Joe Wood
                                  woodsshop.com/
                                  • K Offline
                                    KrisM
                                    Joe,
                                    You can do most of the straight cut with your radial arm saw or a skil saw. Finish the rest with a handsaw (Japanese style is my favourite). Its really not that much work.
                                    Here are a couple of links to various metal fasteners -
                                    http://www.specializedtimberfasteners.com/products/ (look at SFS Intec & Sherpa in particular)
                                    http://www.timberlinx.com/ (An American company)
                                    • K Offline
                                      KrisM
                                      Also -
                                      https://www.grkfasteners.com/
