    Lancashire type steam boilers
    25 Posts 10 Posters 4.3k Views 10 Watching
      shawb
      I have been inspired (and not a little intimidated!) by all the fantastic modelling to be found within these forums. This is my first post to the gallery and hope that it will pass muster. The model represents a common type of steam boiler that would have been installed in countless factories, mines, hospitals etc., probably up to the 1960s. I did try and add some wisps of steam, post production, but wasn't happy with the result - more work needed!
      • ntxdaveN Offline
        ntxdave
        Nice work......looks more like a photo. πŸ˜‰
        Press F1...thank me later
          shawb
          Thank you for the kind comment Ntxdave. Adding plenty of dust & dirt would make it look more like a photo but as with the steam it is harder than I suspected!
          • ntxdaveN Offline
            ntxdave
            I think the texture on the walls ads a nice spark of realism.
              shawb
              The brickwork texture (and a number of others) are from the Sketchup Texture Club. The membership fee of Euro 12 per year is well worth it. Other textures are from SU Podium Browser - my render engine plus a few of my own making.
              • Bryan KB Offline
                Excellent model and renders!
                  liam887
                  Wow really good, I would add some heat blur on those open doors and maybe a glow on the floor/wall just outside them. Those stone and brick textures are top notch!
                  VISIT MY ONLINE GALLERY
                    shawb
                    Thank you both for the much appreciated praise and comments. It may just tempt me to try another post at some point down the line.
                    • tademaT Offline
                      tadema
                      Welcome to the forum and great first post πŸ‘
                      John
                        shawb
                        Thanks John, love the frog!
                          Nicely done, the actual feeder p-lated to feed 'coal' into the boilers appear to all be open, unlikely in real life but otherwise, nice renders.
                            shawb
                            Hi Mike,
                            Thank you for your comments. The semi-circular lower doors provide access for removal of ash which will have fallen through the grate which spans the widest part of the fire tube. These doors would also regulate the combustion air. I agree that they would not all have been open to the same angle - I should have taken them out of the component to show variation on each of them. Fresh coal is fired through the much smaller fire door in the upper semi-circle and these would be kept closed except when firing.
                              Hi shawb, really nice work mate πŸ‘ Only constructive comment I would make is modifying the colour temperature of the lighting. The contemporary lighting source of that era would have been incandescent, so would be a lot warmer πŸ˜‰
                                shawb
                                Thanks for that tip L i am - its something that I should have twigged to!
                                • NemesisN Offline
                                  Nemesis
                                  Very cool! I like industrial thematic, but where is heat insulation ? πŸ˜„
                                    shawb
                                    Hi Nemesis, I debated with myself, long and hard, about lagging the pipes and valves but decided to model the said pipes and valves as a bit more interesting/challenging and have them 'on show'. Not correct I know. I operated steam plant for a number of years and would be the first to appreciate the skill of the industrial lagging specialists so it was a toss up between the two options.
                                    • tuna1957T Offline
                                      tuna1957
                                      very nice πŸ‘
                                        Any render updates?
                                          shawb
                                          Haven't managed to update yet (got side-tracked, which is easy with SU) but will do so soon!
                                            shawb
                                            Once again, thank you all for the comments and observations. I have had a go at addressing some of these and the attached images are the result. Still a long way to go but the process is always interesting! In particular, I tried to adjust the lighting to better reflect the historical period, as suggested by L i am. Initially I added a dash of yellow to the pendant lights but this looked terrible! I looked on-line for RGB values for incandescent light and there is plenty of information available for all kinds of different light sources. Incandescent appears to be more orange and that is where I started from. (RGB = 255,197,41 for a 40w lamp)
                                            • 1 / 2
