    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Google Earth Pro
    15 Posts 5 Posters 1.5k Views 5 Watching
    • pbacotP Offline
      I know the Google feature within SketchUp is gone. OK. We know that...
      Does anyone know if it is possible to put any type of model inside "Google Earth Pro"?
      • boofredlayB Offline
        boofredlay
        Yes.
        Use SketchUp's Add Location to geo-locate your project.
        Save your building (delete all other data) and export it to KMZ.
        In GE Pro go to File/Import and change the file extension to All Files (.)
        Find your file and import.
        This is a quick shape I placed in my backyard just now to test.
        Someone else may have more insight but I think this will only display on your copy of GE Pro. It won't upload to GE for all to see.
        I have used this several times recently to do a quick display of a project on site.
        • pbacotP Offline
          It looks like you have other Google 3d data displayed. I don't have that on my GEPro. How do you get that?
            boofredlay
            I am not sure what is different.
            This is the version I am running.
            • pbacotP Offline
              mine is plain 7.3.0 64bit. But there's no buildings or trees. Just image on terrain.
                boofredlay
                Turn your Sidebar on (ctrl+alt+b) or (View/Sidebar)and turn on 3D buildings in the layers palette.
                • pbacotP Offline
                  Thanks. Now I see!
                  • hellnbakH Offline
                    hellnbak
                    [attachment=0:2t2iectc]<!-- ia0 -->GE Pro.JPG<!-- ia0 -->[/attachment:2t2iectc]
                    So when you look out your back window you see that shape, right? ๐Ÿ˜† ๐Ÿ˜†
                      boofredlay
                      @hellnbak said:
                      [attachment=0:3b2b02aw]<!-- ia0 -->GE Pro.JPG<!-- ia0 -->[/attachment:3b2b02aw]
                      Yep, that is until I shut the program down, then poof it was gone.
                        andre51
                        Thanks boofredlay
                        I've tried it on a golf estate and it works like a charm!
                        Andre
                        • david_hD Offline
                          david_h
                          so Eric. . .what are you planning on doing with that big white box in your back yard? ๐Ÿ’š
                            boofredlay
                            http://img4.looper.com/img/gallery/the-untold-truth-of-dexter/dexter-is-named-dexter-for-a-reason.jpg
                            • david_hD Offline
                              david_h
                              o...kay. .. .
                                boofredlay
                                That is from a show called Dexter. He is a blood spatter forensic expert for the Miami police department. Oh, and he is also a serial killer.
                                • david_hD Offline
                                  david_h
                                  I knew it was from a TV show but one that I have never seen. . ..thankfully. ๐Ÿ˜ฎ
