    Export scenes to 1 file
    5 Posts 3 Posters 919 Views 3 Watching
    • C
      Coolen
      Hello,
      Is there a way to show 4 scenes on 1 page.
      If I now export my scenes, the program creates 4 files.
      something like this:
      https://www10.aeccafe.com/blogs/arch-showcase/2012/01/20/maier-hall-in-port-angeles-washington-by-schacht-aslani-architects/maier-hall-sections/
      • R
        rv1974
        Layout?
          Yes. LayOut will help you do that nicely.
          • C
            Coolen
            thank you, is this a pro feature? Because I can not find it in the menu's.
              LayOut is part of the SketchUp Pro package. Your profile says you are using Make. I guess you could export each view and then import them into a text document or even an image editor to get them to all show in a single sheet. If you want to make scaled views, that gets to be more challenging with image exports and the quality of raster images doesn't tend to be as good as the vector output from LayOut.
              By the way, if you are using SketchUp for your event and conference planning, you need to be using SketchUp Pro anyway.
