    Scene Transition may be asymmetrical
    2 Posts 2 Posters 653 Views 2 Watching
    • fredo6F
      fredo6
      Working on Animator about interpolating Scene cameras as in Sketchup scene animation, I discover that in some cases the scene transition are not symmetrical.
      In the attached model, by TDahl, transition:
      • between Scene1 and Scene2 is symmetrical
      • between Scene2 and Scene3 is symmetrical
      • BUT between Scene3 and Scene4 is NOT SYMMETRICAL
      Animator - Asymetrical Scene transitions.mov
      I have tried to reconstruct a similar camera transition algorithm in Animator. The one I have, not yet released, is usually identical to Sketchup scene animation, except in some of these cases where the camera makes about a half turn. At least mine is symmetrical.
      Has anyone encountered this weird problem?
      I attach the model (SU2017), so that you can judge.
      TDahl - Animator Camera Test.skp
      Fredo
      EDIT: even more weird. The transition path from Scene 3 to 4 is not even always the same !!!
      • D
        driven
        I recall an inconsistency based on the cameras relationship to the axis...
        not sure if this is the same as it was many years ago...
        my 'memory' tells me I avoided this by moving geometry and camera so you never crossed the axis...
        it seemed that if any camera position included a negative, SU makes a decision whether to move clock or anti clockwise...
        and it's not always the same decision...
        does that make any sense?
        john
