    Color not match when render
    renderpluginsextensions
    2 Posts 2 Posters 3.3k Views 2 Watching
      Aditya75
      i'm having problem while rendering
      the color rendering result didnt match with the color that i pick
      below i show the one that use default color, and the other were the one with darken color.
      by the way, i use custom materials
      does this affect? because the issue didnt came up when i use default materials from SU.
      either way also, what should i do, if i'm using custom materials and want to adjust the color level of it, whilst still runs well in vray?
      default color
      darken color
        rspierenburg
        Did you use the Sketchup Material Browser to change the color of the material? If that is the case then it won't change the diffuse texture for Vray. You would have to use Photoshop or similar to change the color of the diffuse texture of the vray material.
