    Vray render setting doesn't save with the file
    renderpluginsextensions
    1 Posts 1 Posters 1.5k Views 1 Watching
    • M
      Marzoke
      Whenever I save my project file the render settings and light intensities don't save with it
      also when I move a component on SU viewport after I render an image then render again the component stays on the old position in the frame buffer
      another problem is that the SU material editor is not linked with vray material editor, so whenever I select a material using the eyedrop tool, it doesn't select it in the vray material editor
      it seems like vray is not linked well with SU
