π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Sandbox Tools
Hi everybody :
When using SANDBOX /FROM SCRATCH, how do I adjust the distance between lines. In Sketchup 8, looks like the default is 10 feet. Question : wouldn't a smaller distance allow for a smoother terrain ? garystan -
@garystan said:
Hi everybody :
When using SANDBOX /FROM SCRATCH, how do I adjust the distance between lines. In Sketchup 8, looks like the default is 10 feet. Question : wouldn't a smaller distance allow for a smoother terrain ? garystanAfter selecting From Scratch, keyin the desired cell size then define the grid. Certainly smaller would mean smoother. Just means a lot more edges and faces to deal with.
@sdmitch said:
@garystan said:
Hi everybody :
sdmitch :
Okay.....I see what you mean, I selected Sandbox / From Scratch. Then...BEFORE......drawing out the "perimeter".....type in the 5' (instead of the default 10'). But, make sure you press ENTER **before** you do the layout. Thanks for your help. garystan -
it is not downloading??
