    Texture direction changes automatically when rendered
    renderpluginsextensions
    2 Posts 2 Posters 1.2k Views 2 Watching
    • A
      avi ben
      i have issue i cant handle,
      i build a small cube, import vismat wood texture, if i scale/move the texture in skp, its changes in the vray render. but the texture direction got 45 degree i cant explain. you can see the attached jpg - the diffrence between the model to the final render.
      i know i can solve it by make the texture in an angle in the model and i will get it stright in the render , but its a bad sulotion for me. did you know the problem/or think of sulotion.
      i have a lot of vismat i collected and its happening in half of them.
      texture direction - compare frpm skp model to vray render
      THE MODEL
      THE VISMAT
      • M
        Mudo
        Try replacing the bitmap on the difuse layer to some other map, I did wth a "Checker" map. Render it, the put the a bitmap again and see if the image gets back to normal. It solved the problem at my computer using the 3.4 version.
