    Enable SketchUp tools
    6 Posts 3 Posters 1.6k Views 3 Watching
    • TNTDAVIDT
      TNTDAVID
      Hello everyone. ☀
      Which code can be used to activate the SketchUp selection tool?
      Is there a list that gives all the codes to activate any tools in SketchUp?
      Thank you
      David
      • TIGT
        http://ruby.sketchup.com/Sketchup.html#send_action-class_method
        Sketchup.send_action("selectSelectionTool:")
        • Dan RathbunD
          Dan Rathbun
          model = Sketchup.active_model
          tool = model.select_tool(nil)
          https://ruby.sketchup.com/Sketchup/Model.html#select_tool-instance_method
          The select tool is activated if you pass nil to the select_tool method.
          See this thread as well:
          https://sketchucation.com/forums/viewtopic.php?t=34840
          For SketchUp versions 2016+ they added new methods for window selection that can be used when writing your own Ruby tools:
          https://ruby.sketchup.com/Sketchup/PickHelper.html#window_pick-instance_method
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            @TIG The url feature is seriously scrwed!
            • TIGT
              I have also just noticed this.
              If you edit a post with a url it becomes messed up.
              I fixed your post's.
              But if you were to edit again it'll break them.
              I'll get Gábor on to it...
              • TNTDAVIDT
                TNTDAVID
                Thank you for these solutions. ☀
