    Enable SketchUp tools
    6 Posts 3 Posters 1.6k Views 3 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      Hello everyone. ☀
      Which code can be used to activate the SketchUp selection tool?
      Is there a list that gives all the codes to activate any tools in SketchUp?
      Thank you
      David
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
        http://ruby.sketchup.com/Sketchup.html#send_action-class_method
        Sketchup.send_action("selectSelectionTool:")
        • Dan RathbunD Offline
          Dan Rathbun
          model = Sketchup.active_model
          tool = model.select_tool(nil)
          https://ruby.sketchup.com/Sketchup/Model.html#select_tool-instance_method
          The select tool is activated if you pass nil to the select_tool method.
          See this thread as well:
          https://sketchucation.com/forums/viewtopic.php?t=34840
          For SketchUp versions 2016+ they added new methods for window selection that can be used when writing your own Ruby tools:
          https://ruby.sketchup.com/Sketchup/PickHelper.html#window_pick-instance_method
          I'm not here much anymore.
            Dan Rathbun
            @TIG The url feature is seriously scrwed!
              I have also just noticed this.
              If you edit a post with a url it becomes messed up.
              I fixed your post's.
              But if you were to edit again it'll break them.
              I'll get Gábor on to it...
              • TNTDAVIDT Offline
                TNTDAVID
                Thank you for these solutions. ☀
