    šŸ›£ļø Road Profile Builder | Generate roads, curbs and pavements easily Download
    Screen Model Clip on Orbit
    4 Posts 3 Posters 761 Views 3 Watching
      blawby24
      I'm running into a problem on orbit and zoom. When I use either tool, the model "disappears" or gets clipped. Here's a video showing what's happening. https://youtu.be/pRI2jPWCC_Q
      • pbacotP Offline
        From the size of you model, clipping may likely be caused by objects far from the origin, or just the model being very big. You can look for objects that are not needed far away to delete or copy out, and move the center of the model or your center of interest to the origin.
        • filibisF Offline
          filibis
          It’s called ā€˜Camera Clipping Plane’.
          You can use Camera > 'Parallel Projection’ to get rid off that effect. (Also use 'zoom extent' tool if necessary)
            blawby24
            That'll do it. I had a mass of people, probably a mile or so away from the origin. Thanks!
