    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Help with holes
    8 Posts 3 Posters 1.6k Views 3 Watching
      JustSumGuy
      hello, I am really new to 3d design and just started with sketchup a few weeks back.
      Doing this for 3D printing and my first efforts are to make some modification parts for my printer.
      Ok my question is this:
      What can prevent the push/pull tool from making a hole from a basic circle?
      I know I am doing it right, I have my model and I make a hole on one face, push it thru to the other face and it meets up but does not make a hole, I can push it thru and back but when its on face it just vanishes below or leaves a circle on the face.
      I know I am doing it right because I can make a box right beside my model and do it fine to that box, but after hours and hours I cant get a hole drilled thru my model!!
      I have installed the Solid inspector 2 and it says everything is "shiny" but no luck.
      What can be stopping this???
      It did work fine, my orig model has holes in it, I just need to enlarge them slightly and I cant because well, I cant!!
      πŸ˜„ Thanx in advance
      • pbacotP Offline
        It can depend on your model. Look at the model with hidden lines to see if your faces are clean (not actually a surface with many faces). The faces have to parallel. could something have changed that?
          JustSumGuy
          I don't know how to check if everything is still parallel.
          no hidden lines tho.
          Attaching file if you want to look. You can see the circle on the face I want to push thru and you can see what I am doing because its done on the other side of the part.
          Sketchup 2017 btw
          E3D V6 holder -1.2.skp
            JustSumGuy
            It appears your right, I checked it the two faces were parallel just by measuring distance on the four corners and they are not.
            Now to figure out how to make them so.....
            Thanx
            • sdmitchS Offline
              sdmitch
              Thanx
              Parallel problem fixed
              http://sdmitch.blogspot.com/
                JustSumGuy
                Thanx sdmitch, can you tell me a little of how you did that?
                • sdmitchS Offline
                  sdmitch
                  I used a couple of Ruby snippets. The first one gave the the Normal of the 'back' face.
                  The second one used that normal and a point on the 'front' face to define a plane. Then each vertex of the 'front' face was transformed so it was on that plane. This made the two faces parallel.
                    JustSumGuy
                    and as I look into that, I can see its way past my level for now πŸ˜„
                    Thank you much!!
                    P.S. my part is printing now and looking good πŸ˜„
