Download problem
I am trying to download sketchup17 make but I keep getting the error msg:
"There was a problem with your form submission. Please refresh the page and try again."
Been trying for two days and different computers.
Usually it's my doing, but this time I am at a lost.
What is the proper technique ?
.... joe
What link are you trying to download it from?
I am using - sketchup.com; what else is there?
that was great but it only gives a partial solution.
Sketchup17 make is a 64 bit product, I need a 32bit product.I built a small cnc(15"x15"x5") using mach3. Mach3 is 32bit system installed on a windows xp computer. So I am trying to use sketchup and g-code plugins on that machine. Where can I find sketchup15 make?
...joe
...joe
You didn't say anything about needing a 32-bit application. SketchUp 2017 is not available as a 32-bit version. Only 64-bit.
See: https://help.sketchup.com/en/article/60107
You'll note that XP isn't supported for SU2015 but that's as far back as you can go now.
yea, I know. I thought there is a site for older products. I can use a win7 32bit machine. there are third party products that converts the pararrel port to usb and onto 64bit, but I want this machine to be in an unaltered state.
Is sketchup15 make a 32bit product?....joe
You didn't look at the last link I provided?
Older versions used to be available but that was in the past. All those old Google versions are gone.
thanks Dave.
you are correct.
I think sometimes I need a seeing-eye dog, maybe two....joe
Register LoginAdvertisement
