    [REQ] Groove maker
    15 Posts 5 Posters 2.3k Views 5 Watching
    • N Offline
      nguyentuyen1986
      I'm working on something that requires lots of groves within a surface. I hope you guys can help write a plug-in that will get this done quickly. The image blow shows what I'm talking about.
      First, we have lines, arcs on a surface.
      Then, we select lines, arcs that we want to make grooves from.
      Next, we put in depth and width of the grooves.
      Most importantly, I don't want the outter edge to be offset (just like the lines and arcs inside it).
      Has anybody done it? Or is this something you can help me with.
      Very much appreciated!
      http://sv1.upsieutoc.com/2017/07/08/Untitled0015e.jpg
      • N Offline
        nguyentuyen1986
        Hi SDMITCH
        Thanks so much for your help! It worked on the surface I gave. However, I tried a different one and it doesn't work anymore. Could you please check and fix it?
        Thanks again!
        http://sv1.upsieutoc.com/2017/07/09/GROOVE.png
        • ntxdaveN Offline
          ntxdave
          Although I do not plan on using it, would it not also be neat if you could create a rounded groove.
          Press F1...thank me later
            Cool but..little glitches! πŸ˜‰
            Sure i have small angles but not very small! (90Β°- 75Β°)
            glitch_circle.skp
              rv1974
              There's free and stable windowizer script for a decade already. The main problem is filtering off those bounding edges, which none of scripts does, unfortunately.
                Windowizer don't works fine with this figure! πŸ˜‰
                Another method(s)
                Select your Upper face
                Deselect "Border Selection" (i don't remember from what plugin it is! 😞 (Selection Toys ? )
                Select "Only Edges"
                Use SU Frame by Suforyou (maybe another plugin can make the uper stripe surface)
                (with a Pro version of SU just a PushPull + Boolean Diff can makes the trick and better than Vishole because you can "extend" the stripe so no need to erase the end faces border! )
                Explode
                Extract the Upper Face
                Use VisuHole
                Erase the end border faces (not a big deal! πŸ˜‰
                Et voilΓ ! πŸ˜„
                  rv1974
                  it's indeed not a big deal for a single forum doodle. But if you fabricate some 30 floor tower (especially with non-ortho geometry) it turns to lots of pain.
                  P.S. try to groove attached
                  Untitled.skp
                  • sdmitchS Offline
                    sdmitch
                    @nguyentuyen1986 said:
                    http://sdmitch.blogspot.com/
                    • sdmitchS Offline
                      sdmitch
                      Fixed the bug but you need to avoid edges/arcs that meet at a small angle.
                      Rounded groove. Something to think about.
                      • sdmitchS Offline
                        sdmitch
                        This plugin was provided for a single request and is not or was ever meant to be a universal solution to all the possibilities imaginable. Sorry it it doesn't work for you but I have no intention to pursue this further!
                          rv1974
                          no problem. just tried to illustrate for Monsieur Pilou the real complexity of the subject.
                          • N Offline
                            nguyentuyen1986
                            Hi SDMITCH.
                            Thanks so much! It works perfectly now.
                            Thanks.
                              I will ask to Fredo maybe to make a little modification
                              for have this erasing side face in Visuhole! πŸ˜„
                                rv1974
                                no Pilou, I guess it'd lead the things to the wrong direction. It should be treated as edge extrusion, not pseudo-boolean imprinfing. But I agree, only almighty Fredo is capable to sort it out.
                                  A little tricky! πŸ˜„
                                  As Visuhole makes a perfect Drill, Carve, Emboss..
                                  Scale your object, scale your Stencil
                                  Apply Visuhole for the groove
                                  And Slice! (With Su_Slice by Suforyou)
                                  Maybe some Guide lines will be necessary...
                                  Will be the same for your mountain surface! πŸ˜„
