    Same Model - Multiple Render Platforms
    3 Posts 3 Posters 1.7k Views 3 Watching
      studioarts
      I would love to know if anyone - with solid experience in multiple render programs has done a test render using the same model on multiple render programs. I am wondering if the cost vs output ratio means anything. Does Twilight Render hold any ground against V Ray or Thea? Or are there other platforms that are comparable. Has to include cost, learning curve, SU/Render platform compatibility, render time, hardware requirements, etc.
        It is easy to do such as test yourself using trial software.
        There's no fair test as each system is different.
        • jujuJ Offline
          juju
          Keep in mind that the different rendering programs each have a "special" way the standard material from SketchUp is interpreted and / or enhanced, but these settings are not compatible with other rendering software, thus you would have to figure out and document an exact way to set various materials / textures in different rendering programs then render them to see how the end results compare.
