    How to model a geometric origami ceiling?
    6 Posts 2 Posters 1.4k Views 2 Watching
    • X Offline
      xLadySakurax
      How do I model a geometric ceiling, comprised of triangular, origami-like folds? Do I start with a triangle, split its faces and use the move tool to drag it manually? Wondering if there's a quicker method or a plugin 😲
      I'm thinking of something like this http://www.archdaily.com/227233/resonant-chamber-rvtr/rc_04
      Would appreciate some help on this.
        If you don't want modelize take a look at Models by TaffGosh
        I believe that you can find something or a module very near that is wished! πŸ˜‰
        Else some plugins like Face Split by Renderiza for divide a triangle!
        Or Split Tools by TIG
        • X Offline
          xLadySakurax
          Thank you! Will have a look at the models and try out the plugins πŸ˜„
          Out of curiosity, how will you model this?
            Seems with
            that will be sufficient! πŸ˜‰
              You must have a little plugin very useful : Projections by Didier Bur!
              With it you can "extrude" a line(s)
              So in you case very practical for make some planes for intersection(s)!
              Just calculate the angle(s) on each side for your specific ceiling!
              Here 45Β°
              Select the top line and follow the vertical line as vector
                Seeing the model πŸ˜„
                So you must modelize it in detail! (one module) with 2 different textures (plain & drilled)
                And use MSPhysics by Anton or Animator by Fredo for anim them!
                Here Animator
                http://images.adsttc.com/media/images/55e8/97b0/6c9d/b519/7f00/007b/slideshow/rc_03.jpg?1441306517
                http://images.adsttc.com/media/images/55e8/96dc/6c9d/b519/7f00/0075/medium_jpg/rc_01.jpg?1441306302
