    Sketchup to Layout references
    2 Posts 2 Posters 7.1k Views 2 Watching
    • T
      tcalvin
      A suggestion for those of us who have multiple SU files buried in Different Layout files. And those of use who's organizations skills are a bit lacking.
      I would love to see a reference list for each SU file that tells me where I've put that particular file in a Layout file. It would be similar to the reverse feature that is already in the LO menu which is "Open with Sketchup" selection. That option is really helpful to get to the exact file you are using within LO.
      If the reverse were available I would be able to identify which SU file I've used in different Layout files.
      Any thoughts out there among the Wizard group?
      Thanks.
      • pbacotP
        I think the "reverse" as you say, is there in the LO Document Setup. You can see all the SU files that are referenced in the LO file, unless I am missing something.
        I have wanted within SU, at least to be able to identify (and open or "go to") the LO files that are referencing a SU file. You have some good points, but I think this simple info would be a start.
